Append data in xlsx file
How can I append data in xlsx file instead of overwritten?
Hi Sagar,
For this, we need to use “Microsoft Excel Writer” step. Following are the configuration you need to do:
“File & sheet” tab:
  1. Select “Use existing file for writing” in “If output file exists” property.
  2. Select “write to existing sheet” in "If sheet exists in output file
    “Content” tab:
  3. Select the check the box of "Start writing at end of sheet (appending lines).
