Active Directory Module installation
Im trying to use the active directory activities on the process studio, but I’m getting this error message as a result.
I believe it is necessary to install Active Directory PowerShell Module
Run the following steps:
1 - Run Powershell as Administrator
2 - Verify that the module is already installed: Get-WindowsFeature RSAT-AD-PowerShell
3 - To install: Install-WindowsFeature RSAT-AD-PowerShell
4 - After installation, check the version and if it is imported without errors:
Import-module activedirectory
Get-Module
Thanks! it worked!
I am having also this issue. How do I use a PowerShell script built using the Windows Active Directory module as an Active Roles Server Script Module? I am trying this I am getting an error that “GEt-ADGroupMember” is not recognized. I think this is because it does not recognize the cmdlet without the ActiveDirectory module.
You need to install the AD module and execute the scripting with a remote session in powershell.
