Capture Debug Logs for Agents
How can I enable Debug level logs for AutomationEdge Agents?
Hi Jane, if you use WF Process Execution, you can set a parameter to record Debug Level Then it will Debug execution according to the level you defined and you can then recall Agent Logs from the AE Server or search the log directory at the agent station.
Hope this helps
