Capture group fields in the Regex Evaluation step
Hi! All
Please could you explain how to capture group fields in the Regex Evaluation step?
The following image shows a workflow execution with results. The workflow contains a Regex Evaluation step.
In the results section you can see the input field - email. You can see the execution result in the result field, Y means regex evaluated successfully. and the two group values after applying the regex on the email.
In the Generate Rows step I have defined an input field email.
In the Regex Evaluation step, I read the input email. I have defined a regex with two groups to capture the string before @ and the second group to capture the string after the @. In the Capture Group Field section, I have defined two Group fields - username and domain.
