Hi Team,
I’m working on a project involving Process Studio, where I need to leverage Process Studio variables with the Table Input step and correctly fetch data processed by an Execute SQL Script. I’ve encountered a few issues and would appreciate your insights.
- Using Process Studio Variables with Table Input Step:
How can I effectively use Process Studio variables within the Table Input step? Are there specific methods or best practices to ensure these variables are correctly referenced and utilized in the Table Input step?
- Fetching Processed Data from Execute SQL Script:
- When trying to fetch data processed by an Execute SQL Script into an Excel output, I ran into issues with column names. I attempted to manually add column names in the Excel output but encountered problems. What is the recommended approach to ensure that the column names from my SQL script are accurately reflected in the Excel output?
Questions for the Team:
- Variable Usage:
What are the best practices for using Process Studio variables in the Table Input step? Can you provide examples or tips for referencing these variables correctly? - Excel Output Configuration:
How should I configure my Excel output to properly capture and reflect the data processed by my SQL script? Are there specific settings or formats I should use to avoid issues with column names? - Data Integration:
What are the common pitfalls when integrating data from SQL scripts into Excel outputs, and how can I avoid them? - Troubleshooting Tips:
If the column names are not being recognized in my Excel output, what troubleshooting steps should I take to resolve this issue?
Your expertise and suggestions would be greatly appreciated to help me resolve these issues.
Thank you!
Best regards,
Darshan Hiranandani
