Can we check Condition in a Data validator,
The Data Validator step allows you to define multiple validation rules for incoming stream fields. It can be used to validate data before it proceeds to the next stage of the workflow.
Common Validation Conditions
- Null / Not Null: Check whether a required field contains a value.
- Data Type & Format: Validate fields as Integer, String, Date, Number, etc., including specific date formats.
- Value Range: Validate minimum and maximum values, such as
Age >= 18andAge <= 65. - Allowed / Disallowed Values: Check whether a field value belongs to an accepted or restricted list.
- Pattern Matching: Use regular expressions to validate formats such as email addresses, phone numbers, or codes.
- String Length: Define minimum and maximum character limits.
