In Remedyforce SD automation workflows I need to manage records in bulk for a large number of modules and fields, for operations such as insert and update. However, entering all the field names on the Salesforce Insert and Update steps; slows down my step configuration. Besides the step configuration is dynamic. Please suggest how I can expedite the configuration and also make it dynamic?
I recommend you enable and use the Dynamic field in JSON format checkbox. The required JSON format is documented in the AutomationEdge_plugin_Reference_Guide. This will address both of your requirements.
