Error Web Gui
How to solve this error? The browser open, but the tab opened is a hello to automation web, not google.com
I experienced as well.
With plugin implemented, the identified URL in start browser should appear a little while afterwards.
Also believe that popup should be enabled for this plugin.
Hope this helps.
The browser open in this tab with welcome and freeze, does not open the URL identified in start browser. I enabled popup, but does not fixed the error. In pipeline, does not generate error in step Start Browser, but in next steps that use browser, does not identify her.
For example, the screenshot shows the start browser for google.com, her freeze in welcome and next step redirect for youtube.com, but generate error.
Confirm that the corresponding plugin is installed.
There is a plugin for each type of browser (Google, Edge, Firefox)
Regards
I solved the problem. I saw the step-by-step instructions for enabling the extension in browsers in the documentation. Thank you for your help.
Can u send me the steps?
In the browser step, click on the help button and scroll to index 4. In index 4.1, it explains how to install an extension in the browser for the step to work.
