Facing problem while using GUI spy
Hi ,
While using Spy Mode in AutomationEdge for Web GUI Automation, my tilde key is not working to exit element capture after indicating an element.
Due to this, I am unable to cancel Spy selection unless I close the window forcefully.
Please let me know if there is any fix or alternative shortcut to exit Spy Mode.
While using Spy Mode, please make sure to click anywhere on the target screen or application to make the window active after indicating the element. Once the screen is active, press the backtick (`) key. This will open the Attribute window and exit the element capture mode.
If the screen is not active, the backtick key may not be detected properly, causing Spy Mode to continue running.
Kindly try this approach and let us know if the issue still persists.
