Fetch specific row
Which method is used to fetch only a specific row from the given data?
In AutomationEdge Process Studio, the method used to fetch only a specific row depends on whether you are extracting data from a UI table (Web or Desktop) or filtering a workflow data stream:
1. Extracting a Row from a Web or Desktop UI Table
If you are using table steps such as GUI: Web Table or GUI: Get Table Data:
  • Action / Selection Option: Set the option to One Row With Specific Columns.
  • Configuration: Enable and specify the target row number in the Row Index field.
2. Fetching a Specific Row from a Data Stream
If you already have data flowing through a Process Studio workflow pipeline:
  • Sample rows Step: Extracts specific individual row numbers or row ranges (e.g., row 5 or 5..10) directly from the incoming stream.
  • Filter Rows Step: Filters and passes specific rows based on conditional checks or key value matches.
3. Reading a Specific Row from Files (e.g., Excel / CSV)
  • Microsoft Excel Input Step: Set the Start row to the desired row index and set Limit to 1 to fetch only that specific row
