Field Value to Run-Time Parameter
How to assign field value to a run-time parameter?
We cannot assign field value to a run time parameter but vice-versa can be done with the help of “Get Variable/Generate rows”.
How to do it?
Hi! Harshita
You can see in the screenshot below, I have defined a parameter P-Stock_Symbol.
The Get Variable step is the second step in the workflow. You can define a fieldname and then specify a variable to assign a value to the field. You can press Ctrl+Space to display the list of variables and select from the list. Else you can type the variable in the format ${variable name}
