File Compare
How to use entry ‘File Compare’?
Hi Sagar,
File Compare is a Process Entry in the File Management Plugin for Process Studio Processes. You can use the File compare process entry to compare the contents of 2 files and control the flow of the process by it. When the contents of the files are the same the success outgoing hop will be followed, else the failure hop will be followed.
In step configuration browse and select files which you want to compare
