Filename in Data format
using Automation, how to give the name of a file in data format(ddMMyyyyHHmm).
Ex:-upload070720201247.csv
Could you please elaborate more, In which case you need this filename: Input/Output?
I’m storing my output data into excel writer but condition is here that filename should be in date format (ddMMyyyyHHmm). How to do this? I have checked predefined data format but i need in this format how to do.
Ex:-upload070720201247.xlsx
You have to create your filename in Modified Java Script Value Step as below:
var Current_Date=new Date();
Current_Date=date2str(Returning_Date,“ddMMyyyyHHmm”);
var Filename=“upload”+Current_Date;
var Filepath=“D:\AutomationEdge\”+Filename;   \\ Where “D:\AutomationEdge\” is path to save output file.
And in output Filename field, pass “Filepath” variable instead of path.
Thanks for solving issue.
Sorry beginner here.
How to pass the variable “Filepath” on the Filename field?
Please check the below solution
