Benefits of Calculator over Formula?
Calculator plugin have inbuilt formulas, simply have to put variables and perform that calculation.
In Formula, one have to create the formula by using samples given and then calculation is performed.
“Calculator” step: This provides pre-defined calculation expressions.
“Formula” step: It can calculate formula expressoins within data stream with the help of formula.
How I would use discount formula in calculator
Hi Bhivraj,
It depends on your calculations to get final output.
The Calculator step have predefined expressions, you can choose from that. Otherwise, use formula step to built your own.
