Hi Team,
I am working on UI automation in AutomationEdge and I need to select multiple checkboxes on a web page.
Using the Spy tool, I am able to identify a single checkbox element. However, I want to select multiple checkboxes dynamically.
Hi Team,
To select multiple checkboxes dynamically in AutomationEdge Process Studio:
Parameterize the locator
Replace the changing attribute (ID, value, name, etc.) with a variable/stream field.
Example: //input[@type=‘checkbox’ and @value=‘${CHECKBOX_NAME}’]
Use a Data Stream
Pass checkbox values/identifiers through Data Grid, Excel, or another input step and build the locator dynamically.
Example: var dynamic_xpath = “//input[@type=‘checkbox’ and @value='” + checkbox_value + “']”;
Use Element Index
If all checkboxes have the same locator, use Element Index (0, 1, 2...) to select the required checkbox.
For Web Tables
Use GUI: Web Loop Table to iterate through rows and perform the checkbox click within each row.
