How do I validate the data inside the Column in an Excel File or of an CSV File?
I have already configured my CSV File in the plugin/design of “CSV File Input” process in the .psw file and now I do want to validate the column name, for example. in the column roles, I want to extract all employees that has the role of software engineer.
are there any query like syntax here in order to establish it?
I am relatively new and does have less than a week since started.
any helps will be appreciated.
please refer to the image below.
Hi @fdc_jpg
If it is a fixed text you wish to filter out, you may use regex expressions.
If you do not know how regex works, it could be intimidating at first but is a very powerful mechanism to identify or manipulate particular strings. Lots of information on the web and to try if an expression works, I use site regex101.
Many plugins you may use REGEX expressions.
Hi! Jai,
You can use the Flow and Lookup category steps like Switch Case, Stream Lookup, Filter Rows etc. to design your workflow.
