How do you handle dynamic web elements?
To handle dynamic web elements (elements whose IDs, XPaths, or attributes change on page refresh or dynamic user actions), Process Studio provides several built-in mechanisms within the GUI Automation plugin family.
Here are the primary strategies to handle dynamic elements:
Strategy 1: Use Relative & Attribute-Based XPaths (Best Practice)
Avoid relying on auto-generated absolute XPaths (e.g., /html/body/div[2]/div[1]/span[3]) or dynamic IDs containing generated numbers (e.g., id="button-12948").
Instead, write relative XPaths based on stable attributes, partial text, or ancestor-child relationships.
Strategy 2: Explicit Synchronization & Waiting
Dynamic web applications (React, Angular, AJAX) often render elements with a delay. Interacting with an element before it finishes loading will throw element-not-found errors.
GUI: Web Wait Until Step: Use this step set to Element Visible or Element Clickable before executing
GUI: Set ValuesorGUI: Mouse Actions. -
GUI: Web Element Condition Step: Checks if a dynamic element exists or is hidden before proceeding, allowing you to branch logic using standard hops.
Strategy 3: Handle Dynamic Frames & Iframes
If elements dynamically load inside changing iframe elements:
Identify the stable selector for the iframe (or use the Frame Locator step / iframe XPath option).
Specify the Iframe XPath parameter directly inside steps like GUI: Set Values, GUI: Mouse Actions, or GUI: ComboBox Actions so the step knows where to search inside the DOM.
Strategy 4: Fallback to GUI Spy / Element Property Actions
GUI Spy Toolbar: Use GUI Spy in Process Studio to inspect the DOM structure and evaluate alternative attributes (e.g.,
name,aria-label,data-testid,title). -
GUI: Element Property Actions: Dynamically retrieve properties or attributes of an element at runtime to construct dynamic selectors downstream if needed.
