How many validation we can perform at time through data validator?
Hi! Shubham,
An unlimited number of validation rules can be set.
Hello Ma’am hope ur doing well… I have a doubt regarding (import project and important workflow & process) what is the difference between both options
Thank you so much
whenever i need to fetch the data from the any website and save it into the excel file . by using web get value how can i do that? what settings i need to that? or i need to used web composite.
Hi Shubham.
Composite step enables to condense multiple steps into one step. For example, Login/Pwd, which typically requires 2 steps that can be done in one composite. Composite are limited to certain steps, for example, DropDown is not available in Composite.
Regarding getting info from web pages, you could Get Value a single item and if reading a table formatted data, you could you the same but would need to loop through it, while Table plugins you can read the complete table in one step and will generate as many rows as are in the table.
Okay…thank you so much ![]()
