How to add API Key for Sends OTP
I need help for generating API key for SMS sending I am unable to generate the API Key please guide me regarding this issue.
@AE_Knights - Can you please help?
Hi! Vishal,
I believe you are using wilio to send SMS for OTP.
Please check the following.
Prerequisites:
  • Twilio instance with access details.
  • Twilio API Credentials which includes, Account SID and Auth Token.
  • Twilio account with a sender number and appropriate access.
References
  1. SMS developer quickstart | Twilio
  2. Error and Warning Dictionary | Twilio
  3. What is E.164? | Twilio
Trial Instance
In case you wish to get started with Trial instance
  • You may obtain Trial API Credentials to begin with on www.twilio.com.
  • In the General tab under Settings scroll to look for API Credentials.
