In above snapshot, we can see the Workflow execution status I want to add hyperlink to counts
eg: if we click on 6 all the rows with failed status only will be downloaded and we can see the data in csv or pdf is this possible
Hi! Shubham, Automationedge Custom Reports have a Drill Down feature. You can explore it. You can try to make a drill-down report that best suits your needs.
