Sample Data:
E101 | Ravi | 01-09-2024 | 9:00 | 18:30 | 250
Requirements:
- WorkingHours = OutTime - InTime
Sample Data:
Requirements:
Step 1: Convert Time Fields to Timestamp
First convert InTime and OutTime into Timestamp format.
Use Rename Field step.
Change the data type of InTime and OutTime to Timestamp.
This ensures that the system can correctly perform time calculations.
Step 2: Use Calculator Step
Add a Calculator step and create a new field:
WorkingTime = OutTime - InTime
This will calculate the time difference between InTime and OutTime.
If you only need the total working hours, you can use the Formula step.
Example formula:
Hours([OutTime] - [InTime])
This function calculates the difference between the two timestamps and returns the total working hours.
