How to use IF condition properly in AutomationEdge Calculator step with multiple conditions?
To handle multiple conditional checks in the Calculator step using the IF function (or NVL/IF-THEN-ELSE functions), you need to follow a specific syntax structure depending on whether you are doing simple single-level checks or nested multiple-condition checks.
1. Basic Syntax of IF in Calculator
The standard IF function in the Calculator step takes three arguments:
Plaintext
IF(A, B, C)
A (Condition / Boolean): A field or expression that evaluates to True or False.
B (True Value): The value/field returned if
Ais True. -
C (False Value): The value/field returned if
Ais False.
2. Handling Multiple Conditions (Nested IF)
Process Studio’s Calculator step supports nested IF statements to evaluate multiple conditions sequentially.
Example Scenario: Categorizing Order Values
If
Amount$> 1000$ $\rightarrow$ “High” -
If
Amount$> 500$ $\rightarrow$ “Medium” -
Otherwise $\rightarrow$ “Low”
Step Configuration in Calculator:
Since the Calculator step works on pre-calculated boolean fields or simple step arguments, the cleanest pattern for multiple logic rules is:
Step 1 (Create Boolean flags using prior steps or basic comparisons):
- If evaluating complex conditions (e.g.,
Status == 'Active' AND Amount > 1000), use a Filter rows or Formula step upstream to generate boolean flags (e.g.,is_high_active).
Step 2 (In Calculator Step):
Set Field:
Category -
Set Calculation:
NVLorIF A B C -
Set Field A:
is_high -
Set Field B:
High_Label(or constant) -
Set Field C:
fallback_field
3. Alternative & Recommended Approach for Complex Multi-Condition Logic
While the Calculator step is lightweight and fast for simple math and basic binary IF(A, B, C), it can become clunky for multi-condition logic because it requires intermediate boolean streams.
