If i already create data base our own and fetch data in process Studio and edit data on backend without using process Studio it will give error or not an edit will reflect on process studio?
You have an existing database with data, and you’re using Process Studio to fetch and process this data. The question is: What happens when you modify the database directly while Process Studio transformations are running or between runs
The impact depends on when the database is modified and whether it is a data change (DML) or structure change (DDL).
1. Database Modified During Workflow Execution
DML – INSERT, UPDATE, DELETE
  • Can cause inconsistent reads or results if the workflow is simultaneously reading/updating the same data.
  • May cause lock contention, query timeouts, or deadlocks when multiple processes access the same tables.
  • The impact also depends on transaction settings and Commit Size.
DDL – ALTER, DROP, etc.
  • Changing or removing tables/columns being used by an active workflow can cause SQL/JDBC errors and step failures.
2. Database Modified Between Workflow Runs
DML – Data Changes
  • Generally safe. The next workflow execution fetches the latest database data.
DDL – Structure Changes
  • Changes such as adding, removing, renaming columns, or changing data types can cause field mapping or SQL errors.
  • Steps with fixed queries may fail if referenced fields no longer exist.
  • Output steps may require field mapping to be refreshed using options such as Get fields or Enter field mapping.
In short: Data changes between runs are generally safe, while structural changes require reviewing the workflow’s queries and field mappings.
