In fuzzy logic for Jaro Wrikle algorithm it’s showing null value in output.
As per the screenshot in the Jaro Wrinkle algorithm, if the string match is greater than equal to four, then it’s showing the null value, and when the string matches completely, then it’s also showing the null value.
Could you please share the workflow, so that we can cross check the configuration of steps.
Please find attached workflow
WF_FuzzyMatch.psw (4.8 KB)
