Hi everyone,
I am facing an issue in Process Studio while trying to dynamically handle database records.
I use the Table Exists plugin to check if a specific table is available in the database.
If the table exists, I route the flow to an Insert / Update step.
The Problem: When configuring the Insert / Update step, I need to define the “Keys to look up value(s)”. However, I am unable to fetch or see the Table field names in the dropdown.
Pushkraj:
The Insert / Update step fetches table columns from the database schema at design time . The dropdown may be empty when:
Target Table is blank or dynamically defined (e.g., ${TABLE_NAME}).
The target table does not yet exist in the database.
Connection or Target Schema is not configured correctly.
How to Resolve
1. Specify a Static Table (Recommended)
Select the correct Connection and enter/select the actual Target Table .
Use Get Fields / Get Update Fields to load the column mappings.
If required, make the table name dynamic again after configuring the mappings.
2. Enter Columns Manually
Type the exact database column names in the Table field column and map them to the corresponding Stream fields .
3. Ensure the Table Exists
If the table is created dynamically, create a sample/existing version in the development database so Process Studio can read its schema.
