Is it mandatory to use the Java bundled in Process Studio
The recommendation is to use Process Studio is bundled with Java as it is also automatically updated when Process Studio is updated.
However, if you must use System Java, installed on the machine outside directory instead of bundled Java,
- Delete the java folder in Process Studio.
- Make sure JRE 11 is installed on the machine with JRE_HOME/JAVA_HOME system variable pointing to the JRE 11
