Problem:
“Workflows stuck in Execution Started Stage, due to this all the other sequential workflows remains in new stage.”
The problem occurs due to input data is more than default limit.
Solution:
- Open the Workflow in Process Studio.
- Double click on workflow, you can see the Workflow properties.
- Go to Miscellaneous tab.
- Change the size of “No of rows in rowset to 100000” which is 10000 by default.
- Save the workflow and export again.
- Check for the exceution status.
