AutomationEdge is a leader in IT process automation. I want to use the amazon EC2 plugins to monitor my EC2 account and perform actions for cost control.
How can I modify an EC2 instance’s attributes? I am particularly looking to resize the VM. What should be my approach to build a workflow for the same?
You can use the Amazon EC2: [C] Amazon EC2: Modify Instance Attribute plugin step to modify instance attributes.
You can modify the attributes listed in the Input section in the image below by providing an Instance ID. I wish to resize the instance. I will resize the instance by changing the instance type. Hence, I have provided a value for the instance type below.
