Scheduler Query
Hi Team,
Can we create a scheduler to execute a workflow on the last day of every month?
E.g: workflow should execute in the below pattern:
31st Jan,
28th or 29th Feb,
31st March,
30th April and so on.
You can create this logic at the beginning of a workflow where everyday it runs and gets the last day of the current month and today’s date. then you use Filter Row Plugin ti check If that is the same date.
It is? it runs, if it’s not it ends without executing.
And at the portal you schedule as a Daily Routine.
Hi Fernando,
Thank you for your reply.
Will try with this logic.
