Problem: ![]()
How to set global variables in process studio?
How to send values from one workflow to other, within a Process flow.
Solution:
Easy solution for global variables ![]()
Step 1: Use Set Variables step to set the variables, which you required to use in another Workflow.
Step 2: Use Get Variables step to get the previously set variables, to current workflow.
Attached are the sample workflows for reference only.
GlobalVariable (1).psw (17.5 KB)
GetV_chileWF (1).psw (13.7 KB)
