Show Workflow Result On AE
How to show Workflow Result message On AE Server execution result
Use the Set Workflow Result step to display a result message on the AutomationEdge server for a particular request.
In this step, you can:
  • Set the Success field (True/False)
  • Set the Status field (Complete / Diverted / Failure)
  • Provide a message (success or error message)
Possible Combinations
Success Field – Status Field
  • True – Complete
  • True – Diverted
  • True – Failure
  • False – Complete
  • False – Diverted
  • False – Failure
Message Behavior
  • If Success = True, the message is prefixed with:
    Message:
  • If Success = False, the message is prefixed with:
    Error:
Exception
For the following combinations, no message is displayed:
  • True – Failure
  • False – Complete
Using Set Workflow Result ensures that the execution result and message are properly reflected on the AE server.
