Guys, I need to use unzip files on the my project. But I dont found on the AE. Someone knows another away to extract files on the zip.
Hello Marcelo,
You can check the plugin “Unzip file” in processes, rather than workflow and you can use that to extract your files.
Thank you so much!
I will create a process an call into the workflow.
