Can we read .xlsm file . If yes how to read and which steps and plugins are required?
Yes, you can read .xlsm (Excel Macro-Enabled Workbook) files in AutomationEdge.
Use the Microsoft Excel Input step (found under the Input category in Process Studio).
Spreadsheet type (engine): In the step configuration under the Files tab, set the Spreadsheet type (engine) dropdown to:
Excel 2007 XLSX (Apache POI)
File selection:
Under File or directory, browse to or enter the path of your
.xlsmfile. -
In the Regular expression or file filter, allow
.*\.xlsm(by default, the browser filter looks for.xlsor.xlsx, so select All Files (.) or type the.xlsmextension manually).
Sheets & Fields tabs:
Go to the Sheets tab to fetch or specify the target sheet name(s).
Go to the Fields tab and click Get fields from header row to populate the schema.
Note on Macros:
Microsoft Excel Inputreads worksheets, cell values, and evaluated formula results from.xlsmcontainers. It treats the file strictly as a data source and does not run or trigger embedded VBA macros.
