What is the use of the Lib_ext folder in the “ae-agent” folder?
Hi Pravesh,
This "Lib_ext" folder is added in AE 5.4v.It is used to keep extra libs that are needed by agent to run the workflows. For eg. you are working with AE 5.2v and you kept extra libs required to execute the workflows via agent in “Lib” folder (another folder available in ae-agent folder). Now, 5.4v has released and you have migrated to that, now, the “Lib” folder will be overwritten after migration and all the libs which you have kept as extra libs needed by agent to run the workflows will be lost and workflows will be stuck.
So, to remove this problem, “Lib_ext” folder is introduced and now you can keep all the extra libs that are needed by agent to run the workflows in it. It won’t be overwritten at the time of migration from older version to newer one.
