If we have created a process and uploads on an ae server, and I want to pass runtime parameters for the process so how can I pass? it has taken default values for workflow which I map in process, so how can I do that?
You have to set process parameters as Runtime true, so whenever you request to run that particular process, it asks you to provide value to that specific field.
To set process parameter, double click in process and provide required parameters.
