How to use AutomationEdge File Upload and AutomationEdge File Download
How to use AutomationEdge File Upload and AutomationEdge File Download .
Hi @pawan.kumar,
Have you checked the Component Reference guide? Specifically 70 and 71 index numbers? If you are still facing any issues, do let us know.
Yes, I checked the Component Reference guide but i did’t understand how to upload file in AE server using AutomationEdge File Upload
Just to be clear,
Do you want the file to be available as a result download or do you want to upload the file to AE server for processing?
Can you please provide one workflow example of both
I think it would interesting to have some sample workflows for some basic/advanced features.
Agreed.
Actually, The training team is working on this already and we will publish them as soon as we can.
Either me or one of my colleagues with respond with the required content.
upload file to AE server For Processing
Hi @nehamitkari,
Welcome to the community. To have file as a runtime parameter, create a parameter of type File and for Runtime select True. You can give a default file location for testing. When you publish this workflow, you will be able able to upload a file as a runtime parameter from the Catalog.
oK Thanks for the help. @hemanshu.rukadikar
But if i want to trigger the workflow through postman (
with the following URL(https://t3.automationedge.com/aeengine/rest/execute)
then what should be in my requst body section? (for file upload )
can u please guid me for this?
Sure,
Please share your email ID so that I can share the API guide with you.
