File Upload or Download from AutomationEdge Server
How can I upload or download files (such as .csv or .txt) from the AutomationEdge Server to be used for operational purposes by AutomationEdge workflows ?
Hi! Marco
Following are the Process Studio steps readily available File Upload/Download to AutomationEdge server.
AutomationEdge File Upload
The AutomationEdge File Upload step uploads files to be consumed by AutomationEdge File Download step in one of the next steps in a workflow using the File Identifier from the upload step. Note: This step can be used to design a workflow however, it executes meaningfully only once published on AutomationEdge Server and when executed by Agents
The AutomationEdge File Download step downloads files uploaded by AutomationEdge File Upload step in one of the previous steps in a workflow using the File Identifier from the upload step. These files (such as .csv or .txt) are mostly used for operational purposes by a workflow. Note: This step can be used to design a workflow however, it executes meaningfully only once published on AutomationEdge Server and when executed by Agents.
Get Files from server
Get Files from server step downloads Agent/Workflow files from server at runtime, when executed from AutomationEdge server. Note: The file name should not be changed when updated from AutomationEdge UI; only then the workflow will be able to pick it up. If there is filename change, the workflow also should be updated accordingly.
