My AE Agent would reside inside a VDI , please let me know if there will be issues with UI and API automation.
Thanks
Mahesh
Thanks
Mahesh
Hi Mahesh.
You shouldn’t. If you need to display a screen, for example to capture images from the screen, you will need Remote Desktop to do so. Then you will need a controller to login remotely with RDP. With the controller, you can also start/stop agents.
For example, ScreenCapture plugin, you will have to display the image, know the coordinates where it is located and then capture the image.
APIs should not be a problem.
