In our real-life implementation, up to what percentage implementation of automation edge is possible?
Hello Pranit,
This entire depends on the nature of processes that you encounter. For instance, if you come across only rule based processes that do not need any human intervention, the percentage can be as high as 100%
However, if you come across a lot of processes that are based on human intellect and have no proper rules defined then that percentage may drop down drastically.
Warm Regards,
Hemanshu Rukadikar
