Can we convert field to variable in single workflow?
I am getting the path of the file in feild and want tk read this file
I can’t use this feild in input step file path as it requires variable$.
I want to do this into single workflow. How it can be done
Hi @Shubhamautomation,
Which input step are you exactly using? I am asking these because for multiple steps, you can use field names directly.
I was downloading the attachment from mail. Email message input step was creating Mail folder like
mail10280, mail10390 etc. And inside this folder downloaded file exists.
That i wanted to read .
email input step gives the attachment folder path as field. and In input step(Text file input)
to use this path we normally use variable$ name But to keep the value in variable we need to use another workflow(pass path as Runtime paramtere and use that direclty in file input step).
But
I wanted to in single workflow.
Now I got know the about cool feature in input step.
In which we can use field(froom previous step) in filepath to read file( see snapshot)
Good to know you could solve it! Kudos!
