How to set dynamic file path from email message input to text file input.
I want to set attachment folder path in text file input step that is coming from email message input step.
Hello Onkar,
Greetings!!!
Kindly try to check the workflow attached and let me know if you are looking for this.
Regards
Gaurav M
email-fileoutput.psw (19.7 KB)
Hi Garr,
Yes, I’m looking for this only but i solved this issue using javascript step. path and file name attached and assigned to variable and selected variable name in text file input step.
Hello @onkarhiremath
Oh Sure you can also go with that approach.
Glad to know, thank you for the update.
Regards
It’s not work. how to solve this problem.
I solve this error but how to fetch data from that downloaded file path in text input step
