Can we use Single Agent with multiple systems?
Can we use Single Agent with multiple systems.
Hi Shital,
Yes, we can use a single agent with multiple systems.
To do this, we need to download agent on another system and run it.
Hello Shital,
I am assuming that when you say A Single Agent, you mean one agent (like one entry you can see on the Agents tab in UI).
If my assumption is correct - a single agent - then the answer is no. One agent can run only on one machine. You cannot actually run that same agent on multiple machines.
