Convert into Zip File
How to convert Json file into Zip file?
@Vaishali You should try using the ZIP step:
Hello @fbaldin ,
Could you please guide me how to convert Json Output to Zip file.Please find the screenshot attached below for the refrence.
@Vaishali see…before zipping you need to make the JSON Output, a file, right? otherwise is just variables from the workflow.
Add a Text File Output, create an Text file from the JSON Output, then you zip the result file, got it?
Yes Got it.
Thank You :+1:
