Hi
In order to create a variable with the date you can use Modified Java Script Value with the following code, this will give the output: dd/mm/yyyy
*var today = new Date(); *
*var dd = today.getDate(); *
*var mm = today.getMonth()+1; //January is 0! *
*var yyyy = today.getFullYear(); *
*if(dd<10) { *
- dd = ‘0’+dd *
*if(mm<10) { *
- mm = ‘0’+mm *
today = dd + ‘/’ + mm + ‘/’ + yyyy;
