Hi Team,
If I want to get the current date then how can that be done in PS.
Hi Team,
Hi Sonam,
Write below code in Modified javascript:
var current_date=Date();
var current_date=new Date();
Above format is the correct format to get current date.
Also if I want to fetch the current date which I have received from Modified Java Script into some text file how can that be achieved. If I use text file output to get the current date from Modified Java then I am just getting the variable name but not its value.
Hi Sonam,
You can also use Get System Info.
Hi Sonam,
There are multiple ways to fetch Current date:
Workflow Execution:
Thanks Ankita. Its working as expected.
That’s Great Sonam !
