What is the use of Element is dropDown in Web Get Value Step?
Hi Komal,
It is used to retrieve the value from the Dropdown Element. This field has value Yes and NO. If the element from which we retrieving is Drop Down then select Yes. It will retrieve the value visible in Dropdown Element. If you want to select any specific value from Drop down we need to first set the value in Dropdown Element.
