How can we format the excel output file in specific format ??
To format the Excel output file in a specific format in AutomationEdge, you can use a pre-formatted template approach
Step 1: Create a Pre-Formatted Template
Create an Excel file manually.
Apply the required formatting:
Header font (bold, size, color)
Background color
Borders
Column width
Alignment
Number/date format
Save the file as a template, e.g.,
Salary_Template.xlsx.
Step 2: Use Microsoft Excel Writer in Process Studio
Add the Microsoft Excel Writer step and configure it as follows:
Template Name:
Provide the full path of the formatted template file.
Example:
C:\AutomationEdge\Templates\Salary_Template.xlsx
Template Sheet Name:
Specify the exact sheet name from the template.
Example:
Sheet1 or SalaryReport
Start Writing Cell:
Mention the cell from where data should be written.
Example:
A2 (if row 1 contains formatted headers)
Write Header:
Yes – if headers need to be written dynamically
No – if headers are already present in the template
Output File Path:
Provide the final path where the formatted output file should be generated.
