Problem:
AE 5.3
Issue while executing PowerShell script from Process studio.
Finished processing?? But no output generated.
Solution:
Try below solution:
Open process-studio.bat file (ex. D:\process-studio-5.3.x\process-studio.bat) in Edit mode.
Remove “-XX:MaxPermSize=256m” from PROCESS_STUDIO_DI_JAVA_OPTIONS.
Open Process Studio and check with script you are executing through ‘Execute PowerShell Script’ step.
