Problem Statement: Facing issue while opening PS & starting Agent on the client machine.
Error: failed: connection time out on agent console. Got the error as per the attached screenshot.
Below are the solutions we have tried:
1- tried by running the process-studio.bat file as well startup.bat file as administrator
2- Tried by disabling the proxy from the machine
3- Setup proxy on AEUI and downloaded the proxy file and put it into the agent/conf and process-studio/conf folder
4- Try to run the process-studio and agent with localhost configuration
5- Try by adding proxy setting with Authentication(username & password)
We have tried all the possibility but still, the issue persists. Could you please suggest on this?
