Problem:
Unable to establish connection to pgAdmin Database from another remote server
Solution:
To access the database from another server, you need to add that machine IP address into the Postgres configuration file.
Please follow the below steps to add the entry of remote server (In this case, it is 10.1.42.141):
Go to the PostgreSQL installation directory, mostly it is present in C:\Program Files\PostgreSQL\9.5\data path.
Edit the pg_hba.conf file from this location.
In this file go to the # IPv4 local connections:
host all all 127.0.0.1/32 md5 -
Add the IP of the machine from where you want to access the PostgreSQL database, in this case it is 10.1.42.141
host all all 10.1.42.141/32 md5Refer below image:
Save the file, restart the Postgres database service, and check the connection.
